inside remote wont lift our 22 ft disk up , outside will but slow & sometimes it wont lift at all unless you pull lever very slow till it starts lifting then its ok , all other hyds. like 3-point power steering , brakes work fine , 3-point lifts 5 bottom semi mounts plows fine , anyone have idea"s , cant belive it would be pump itself when everything els works , also havent tested pump pressure but can adjust it till engine will labor fairly hard, so id say its pumping good pressure , mybe someone els has had this problem , i forgot to add the remotes are detent valves , no float valves on this tractor , thanks to all that can help
