NewOldFarmer
Good afternoon all, So my 8N may have a serious issue. It was overheating, so I put it in the Garage and
tore it down, out a new Head Gasket on it (it overheated really bad while brush hogging)and then replaced
the entire cooling sustem. New Radiator, water pump hoses, and she started and ran just fine. But again
after running about 10 minutes she started overheating. A lot of steam coming out from what appeared to
be the lower front end of the engine. I couldn't get close enough to see well. I have a friend who is a
master mechanic checking head pressure etc... but the more we talked, the more it sounds like it may be
the block itself. Has anyone ever had an issue like this? And does anyone know if Blocks are available?
I am thinking I will buy a non-running 8N to use as parts if the engine is good, but just in case, I am
looking for possible blocks as well. Any info is greatly appreciated.
