I have a 1957 850 that I think I have cracked the head or block when a piston came loose from the rod. I haven't had time to pull the engine and carry it to a machine shop for testing. However, I have found what the owner says is a 1956 800 for $1600.00. It starts and runs great and all the sheet metal is straight. Its a decent looking tractor for a worker. I am thinking about buying this tractor and installing the engine in my 850 and using the remainder for parts. The reason I don't just use the 850 for parts is because it has all the brackets for my loader. I cannot read serial no. on the 800, however the engine casting no. is EAF 6016R as best I can tell. From this no. can you tell if its a 172 CI engine that will fit in my 850. Also, the transmission on the 800 is a 5 speed that shifts forward and back. My 850 has a 5 speed that shifts up and down and right to left. Thats another reason I like the 850 for use with the loader. Third to Reverse is quick and easy. Is there any problem with bolting the 800 engine to my 850?
Thanks
Clay
Thanks
Clay
