I have recently purchased a 1961 Case 530 Loader/Backhoe (model 31) about a month ago. When I purchased it the clutch worked but was a little spongy in my opinion. The young man I purchased from said the clutch was a few years old and he did not use the tractor much since then. The first day I used it the clutch stopped working. As far as I know I have a standard clutch, shuttle shift with high/low and 4 gears to have 8 forward gears and 8 reverse. As of now I cannot engage the motor unless I turn the tractor off, put it in gear, and then start the tractor in gear. If I try to release the clutch as you normally would in while its running, the tractor does nothing(stopped and never moves). A few times I was able to tap the clutch many times and also ever slow slowly release it ( like 30 seconds to full release) and the tractor will SLOWLY start moving. I have tried to adjust the linkage to the clutch from the pedel and got it to engage a few times but feals like it is lower power. When you press the clutch pedal while the tractor is off the pedal feels strong, however, when the tractor is on, the clutch feels very soft. I did order a clutch, pressure plate, thowout bearing and bronze bushing and have the 4th of July weekend planned for my first ever tractor splitting! My question is, what went wrong with the original clutch that was replaced? Did the last guy not adjust the pressure plate? Do you even need to adjust the pressure plate. And is ther anything else it could be instead of the clutch? Thank you so much! Jake ![Big grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
