(quoted from post at 18:37:03 05/22/23)
(quoted from post at 15:49:05 05/22/23)
I bought this thing in 2006 put the filter on not long after that only recently started having this problem so I don't think that's the issue.
Or the gas cap ins't letting in air. I take it the cap suppose to let air in correct?? No other way for air to replace the used fuel that I can tell.
If it has been about 16 years since the filter was new, I'd say definitely time to replace it. Also the rubber lines that were added. .
Also make sure that the filter was installed in the correct orientation. Generally the fuel should flow around the outside of the paper element, through the element and then to the carb.
If the filter was not marked with the correct direction for installation, The pointy end should be at the tank side and the wider flat end should be at the carb side (the outlet). And ideally the filter should be oriented vertically.
If you install it backwards, all the dirt and and any rubber particles from a 16 year old deteriorated hose will be trapped inside the element space, as will any bubble, either air or vapor (as in a lock). And the dirt won't be visible outside of the element.
I know you say you think that the filter is fine, because of the good rate of flow through it when it hasn't been working, but again, remember, that is the time when everything works well. If AFTER working for awhile, the air gets in, or loose particles get trapped, or the filter gets hot and a vapor bubble forms inside while you are working, is the flow good then?
A backwards installed filter would exaggerate these problems.
And of course test the plugged tank vent possibility next time you're working and the tractor is stalled. Loosen the cap and try starting the tractor immediately. This has been suggested by several people before.
Finally be open to the possibility that there are multiple issues -- that was the case for me. Replacing lines cleaning screens, making new gaskets, and making sure the carb was in perfect working condition, restored all reliability.
This post was edited by vtford800 on 05/22/2023 at 10:51 am.
