My clutch is starting to slip in high gears with a load. I just put in a new friction disk and new pressure plate a few years ago. We are very easy on equipment.
When I replaced the friction plate and pressure plate last I thought that it was unusual that the friction plate was only wore down .010" or .020" (I forget, but it was no where near getting into the rivets). The flywheel looked good, no grooves wore in etc.
I did not measure the flywheel at the time, but I'm now thinking that the flywheel is probably wore.
Is there any way to build up and machine down a flywheel? Or shim it out? Or am I probably in for a new flywheel?
Thanks,
JP.
Thanks,
JP.
