Ok fellas sorry for the late reply but its been a busy week.
Finally got to go work on it yesterday.
Stuck new distributor on, hooked up plug wires, it ran EXCELLENT....
For about 2 minutes. Before it died out in the yard again. Just like someone shut the key off. No spark.
What in the world is going on here? I noticed the coil wire connector was iffy, replaced that. Got it to kinda run at like 100rpm for 20 seconds on maybe 2 cylinders after extended cranking.
The ceramic resistor was blazing hot....not smoking, but burned my finger. Is this normal?
Is it wired right? I cant find a 12v diagram....just factory setup ones. Its got 2 wires coming from the ignition switch. One im guessing is power in, then one running to the ceramic resistor. Then from the resistor there is a brown wire that runs to the coil.
However there is an orange wire that wasnt hooked up to begin with, that looks fairly new, that comes off the factory ballast resistor. I have no idea what its for. Could that be the issue? Where the heck would it go? Its only long enough to reach the ceramic resistor.
Im literally pulling my hair out on this thing. Everything is new besides the ignition switch (which is working, tested) and the factory ballast resistor.
Please advise...lol.
