(quoted from post at 15:46:42 08/23/12) Can I remove it without taking the front wheel assembly off?
(quoted from post at 07:50:02 08/24/12) 1. Tractor bogs down - seems like hydraulics are loading up.
2. The front loader won't stop - up or down - when lever is released.
3. When I raise the three-point, the loader goes up.
4. Three-point wont stay in position.
5. Lose power steering.
6. Power brakes lock.
(quoted from post at 08:57:09 08/24/12) Or on Waterloo tractors there is a handy line that can be T''d into. Line runs from the scc return down to the trans case , close to the filter.
(quoted from post at 18:35:27 08/24/12)
If the front pump is lugging the engine when no hydraulic loads require oil. There is cause for concern.
(quoted from post at 09:42:22 09/12/12) Is the stroke control valve a repairable item or does it have to be replaced?
