DairyFarmerInMA
I'm looking for some insight on my hood and gas tank fill neck. The tractor is a 310B serial # 6099962. I'm also curious to know what year that makes it. The fill neck is located in the middle of the tank, my operators manual and parts manual (R.I. A377) don't agree with one another. The operators manual shows the gas tank fill neck toward the front of the tractor accessible through the same cover as the crank case oil fill. The parts manual show the fill neck in the center of the tank. Confusing things further it appears as though the hood pieces in the same parts manual don't allow for a way to access the gas tank fill neck without removing the hood. My questions are:
Do I have the wrong hood section or the wrong gas tank?
What is the difference between round nose and square nose hood and gas tank?
What are the correct part numbers and terminology to find the right hood or tank?
The numbers are as follows
Tractor 609962
Engine (stamped right side by filter) 181P06671
Gas Tank G15565
Hood (I think I have) G16717 (Gas)
(Not) G15565 (L.C.F.)
As always thanks in advance for you help. This forum has a lot of great people on it and has truly stoked my interest in CASE!
Tractor 609962
Gas Tank G15565
