I have a 67 4020D. I was out mowing weeds when I accidentally ran it out of fuel. After adding fuel and using the manual pump to fill the fuel filters, I attempted to start the tractor but the batteries gave out after just a few seconds. (I have converted to 12V and am running dual 6V batteries) The batteries were 4 years old so I bought new ones, put them on a 2A trickle charge overnight to ensure they were topped up, and installed them in the tractor. All I got when I tried to start it were little buzz/rattle sounds from behind the dash. I called a local dealer and their shop guy said try replacing the starter relay, so I got one and installed it. I took a photo of the old one before I took the wires off and reconnected the wiring to the new one with that as reference. When I hit the starter button afterwards, all I got was one little fzzt and now the two idiot lights on the dash (electric status & oil pressure) are dark. I get nothing when I turn on the key.
I've undone and cleaned up all connection points, battery terminal connections, sanded every spade lug to bright metal, etc.
I've ordered the I&T manual for it just now, and look forward to examining the wiring diagram therein, but would appreciate any advice the community has to offer on my problem, cause my tractor is now sitting 1/4 mile away from the barn out in a field and that just ain't right! Thanks in advance.
Does this thing have a fuse somewhere?
Should I try jumping the starter with a big screwdriver to see if it will crank the engine?
