Looking for subject ring gear I noticed that Yesterday's tractor offers a ring gear that the description says it replaces the Carrero. However the ring gear on my 4630 has a backing plate and 2 studs and 6 bolts that are integral to the backing plate. This plate with ring gear attached goes directly into the front hub. So, if I don't get an exact replacement and use a ring gear that slips inside the planetary cover and engages the planetary gear without being attached to the front hub will it work, or will it not work and potentially cause damage? Thanks very much . btw, 4 of those 6 bolts were sheared off, in consecutive order and the planetary cover has 2 holes ripped in the side, 1"x3" , and the rind gear has several teeth broken. The planetery gears, their shafts and the splined axle shaft and bearing looks ok. Not sure of the cause of this. The tractor only has 1300 hours on it and is in great shape otherwise. It was being operated on soft ground and not hard surface when it broke, no load in bucket.
