CapLoneStar
Hydraulics worked two weeks ago when I bought the tractor. It turns out the hydraulics fluid was leaking into the crankcase oil so I did an oil change and replaced all the seals and gaskets in the hydraulic pump. I put two quarts of 30W oil into the hydraulic pump and started up the tractor. From what I can tell, I don t believe it is leaking anymore; so that s one problem solved. Long story short, now the hydraulics aren t working. When I push the throttle all the way up and adjust the touch controls, it sounds like it is trying to work. I ve rotated the rear bar, so I know it s not jambed. Air in the system? Not sure what the issue is now, thoughts?
