Tractor was running but with alot of blowby oil everywhere. Had engine rebuilt by reputable company although they don't sepcialize in tractors.
Before engine rebuild had injector pump (Roosa Master)rebuilt reinstalled in tractor and it ran fine.
After engine rebuild replaced injectors with rebuilt tuned injectors.
Manual says to time injector pump you line up 3 things: # 1 18deg BTDC (most new documentation now says 23 BTDC),marks on the injector pump, and the slot in the pump drive shaft almost horizontal with the large part of the lobe towards engine.
Checked for #1 BTDC by watching #1 exhaust valve open then close then watch timing marks on fly wheel to confirm TDC on exhaust stroke. Then continued to rotate crank by hand and watched #1 ex valve close and intake open then watch for flywheel timing marks again....and stop @ 23 deg BTDC.
Primed engine with motor oil before installing injector pump.
Tank was emptied and refilled with 8 gallons fresh diesel fuel.
Bled new filter and checked for pump prime by loosening prime hose from fuel tank to pump and fuel pours out.Cranked engine with injector lines from the pump NOT connected to the injectors an watched for fuel to squirt from the lines and it does. Tightened injector lines from pump to injectors.
Battery is new and starter spins well. Tried different throttle positions.
All I get is white smoke with no popping at all. Tried many times killed battery, charged battery and tired again with no success.
Removed injector pump and redid above sequence verifying all as indicated above.
Tried again noo success just white smoke...
So what did I miss ??? Is 23 deg wrong ??
Engine did sit for about a year without being installed but fogged ports with WD40 and sealed with tape.
When I crank it by hand I really have to lean into it when a piston is in compression. I assume that means I have comnpression ??
Any suggestions welcome ...
Thanks...Alan
Thanks...Alan
