Fred from MO
So has anyone pulled the powershaft drive gear to replace the seal behind it. (The gear on the crank where the red arrow is pointing)? My gear puller wont reach that far from the end of the crank so I may have
to modify it. I cant remember if this gear comes off relatively easy with regular gear puller actions or if anything special is involved so I thought I would ask on here. Also is removing that seal easy enough
to do with a standard seal puller and installation as simple as knocking in a new one? I dont want to have to pull the crank as I understand the main bearings for the 720 are no longer availible?
