Turning cold here. Down to about 15-17ish yesterday morning. Had a chance to tinker with the 756 gasser. Pulled the choke, hit the start button and it fired off like a champ. I'm liking this gas and colder weather combo....
I'd like to put my 3pt carry-all on it and haul out some firewood with the tractor. Still very much in the learning curve with this tractor. We've got a couple of roads on the place that are somewhat steep. Steep enough I'd never pull a wagon full of hay behind this or any other tractor we've got.
I've read much about Allis Chalmers WD45's popping out of gear on a down hill run.
Question is - how is the 756 when it comes to popping out of gear when being pushed down hill? This 756 has a factory TA delete, so that isn't a consideration/problem. Brakes seem to be OK - just don't want to go there....
Also, about 3 inches up from the bottom of the oil pan is a petcock on the RH side of it. I'm assuming this was a previous owner addition and its purpose is to give an indication as to when enough oil has been added vs tinkering with the dipstick? Why would someone otherwise add a petcock to the side of the oil pan? A friend of mine said he had seen this on some older Farmalls.
Thanks!
Bill
Thanks!
Bill
