Hey all, first post here.
So I've been stalking this forum for a while but now I need some help on a topic that I can't find an answer to.
I have an 851, 1961, that has been converted to twelve volt, ran great ever since I did the conversion. I had some carb issues today so I pulled the carb fixed it and put it back together. Fired her up and started right up and idoled just fine. Put it in gear took of and it stalled, ok need to tweak the carb adjustments no problem. Went to start it back up thought it was going to fire it didn't and so I hit the starter button again, I THINK the starter was still spinning when I did this. After that nothing happens when I hit the starter button. Like the battery was taken out of it.
I tested the push button with a test light, got power as it should.
Battery is at 13.xx volts.
13.xx volts on both sides of the solenoid
13.xx volts to the coil
When I put it in 5th gear and rock it the fan spins.
13.xx colts to the wiring going to the starter
Good voltage on the key switch
I don't know? When a stuck bendix cause this problem? I'm a guy in my 20's and I know these tractors are common sense, but this isn't common to me so throw me a bone!
Thanks guys, and gals
