LarryMaine
This is all so embarrassing. With engine rebuild done, I fixed the timing, and I have now replaced the rear main bearing cap seals, re-married the engine for the second time, and I fixed the main leak just fine. BUT and hopefully my final screw up, smoke was coming out of the timing cover hole, obviously clutch was burning with trans in neutral. After depressing the clutch pedal I can not get it into gear, they just grind. I went to the manual and properly adjusted the free travel play for the clutch pedal, no change at all. So, before I separate the engine for the third time, does anyone have any suggestions. Nothing available in the manual or YT archives. The 850 does not have the two clutch release springs, it just has the one spring wrapped around the bar in the clutch housing. And yes, I did replace the clutch pack and the disc, also the pilot bearing and throw out bearings, and I used the alignment tool. The engine remarried to the housing fairly easily, I did not have to force the engine in at all. All I can figure is the disc is in backwards, the spring is broken but it looked just fine prior to reassembly, or somehow I damaged the clutch fingers somehow? Anyway, anyone have any experience with a stuck clutch after a rebuild? Thanks again as always, this is all embarrassing enough as it is.
