I used my '51 8N for a couple of hours to pull some small logs out of my woods. The 8N was doing fine but stated to miss and die down and would not stay running. I checked fuel and it is there at carb bowl drain. so i checked the spark and it seemed to have some at time then not. I opened side mount dist and see the points spring looks sprung out. I had a ignition kit on hend so put the new points, condiser, rotor, dist cap in. but still no crank and no spark. I have been using an old 12 volt bat to crank and run it so hope I haven't overloaded something. I double checked my work in the manuel i got from Y.T. And i believe i did the points ect correctly. but i still do not get spark at plug wire. did i burn up the coil or something using the 12V battery? How can i test the coil to see if it is ok. Or give me some pointers on what to do next please. thanks jim
