green_achers in MS
Hello, everyone, first post here. I have an 8N with side-mounted distributor, but indeterminate vintage. It has been one problem after another since I bought it, to the point that we have named it "Art" for "Yard Art", which is about all it's been good for. I so far had to take it to a repair shop for a crack in the block and a worn governor. Now I am having trouble getting it to idle right and maintaining oil pressure. Here's the symptoms:
Once started and warmed so I can let got of the choke, it will have an oil-pressure reading of about 20. After as little as a half hour, it will be down to about 10. Yesterday I got one of the longest work sessions out of it, but the pressure was down to 0 after about 3 hours.
It also starts out running pretty smoothly, but after a while gets really ragged. I see a bit of dark smoke at the exhaust and at the oil filler and engine oil dipstick. I am still just figuring out the controls, and the throttle has me pretty confused. At the middle point of the arc, it will be very slowly idling or as it heats up, it will shut down. I don't have a tach on this tractor, so I can't give the RPMs. On the lower quadrant, it just dies. I haven't figured out what this quadrant is for. The tractor seems to run best near the top of the upper quadrant. However, if I try to set it all the way open, it bounces back to about 90%.
I fooled around with the carburetor screw on top, which I am guessing is the main jet adjustor. It got a lot of the roughness out at idle, but I still have to keep the throttle pretty open. I can see a smaller screw on the lever connecting the cable from the governor to the carb. I'm guessing this is the idle, but don't know how to adjust it. Should I try to adjust it so that the lower quadrant gives me a low idle, or is this sector for something different?
I am also concerned that the problem might be in the fuel line to the carb. I do see rust in the resevoir almost every time I check, and I have flushed out the carb and lines once. It seemed to help a little, but not enough to know if this is the problem. Should I drain the tank and clean it out? Also, I can't figure out how to get to the filter inside the tank.
What are the chances that the oil pressure problem is related to the throttle/carb problem?
As you can probably tell, I'm pretty inept mechanically. I am almosty as old as this tractor, so I can remember carburetors and distributors at least well enough to have some theoretical knowledge. But it's been a long time since I turned a wrench on anything like this.
