flatheadvff
I use 10si internal regulated gm alternators on most of my tractors. I use the 3 wire versions, not the 1 wire as most tractors don't spin fast enough and have trouble energizing. I have a 1 wire on a tractor I recently bought and it isn't working. Switched it out with a 3 wire I had on the shelf from a rebuild shop family has been using since the 60s. Hooked up my wires and it still doesn't work. Disassembled both alternators and tested components, which test good. Only thing I don't have tool to test is the regulators. (Had one back in the day but can't seem to locate it). Growing up in a parts store and garage, I remember that one could ground a point in the back of the alternator and get unregulated charge. This would let you know if the alternator was able to charge and that the regulator was most probably bad. Problem is I don't remember where said point to ground is. If anyone knows I would appreciate the Information and a picture would be, as they say, worth a thousand words. Thanks LJS
