connor9988
- Location
- Central Iowa
As many of you know, it is pretty cold and miserable outside. I am stuck inside theorizing on new projects for the future...
I found some pictures online of a J-series plow that had been brought down to a 3 bottom. From what I can find in the manuals they were 4-6 bottom semi-mounts with Category 2 drawbars. This one has had a Category 1 put in its place so that it can be pulled with an eagle hitch tractor. Bringing one of these down to 3 seems easy enough but I think with just a little more work a 2 bottom version could be do-able.
Why? It would be a neat project and something unique. I could certainly run a 2 bottom version with both my VAC and 311 (and any other eagle hitch tractor) and it would be easier to load on a trailer.
The tailwheel assembly is modular so it would be easy to move that up to #2 bottom and the same would go for moving the hydraulic lift hardware and the steering pivot point up to accommodate 2 bottoms.
The hard part would be getting the proper tractor/plow spacing when I move the drawbar mast over to between #1 and #2 bottoms.
I don't have a J series plow just kind of thinking out loud...
