Here's the skinny on FORD/M-S Carbs:
MARVEL-SCHEBLER CARBS USED ON THE FORD N-SERIES TRACTORS
The original TSX-33 has a large round knurled splined thumbscrew as the main adjusting needle with a spring tension ratchet clamp to keep it from moving. Since the TSX-241B superseded all other N carbs, the newer Main Jet screw would be correct on any N carb. FORD UPC nomenclature designates carburetors as group #9510. The TSX-241 models biggest changes were the revamping of the Main Idle Air Jet Adjustment and the Main Throttle Adjustment Screw. The TSX-33 Model required the operator to make adjustments using hands-on turning the Main Adjustment Screw/Knob and Throttle Idle Screw. This was hazardous to the operator because adjustments had to made when the engine was hot and thus working close to the carb often resulted in the operator burning his hand. With the new TSX-241, the two adjustments screws were redesigned using slotted head screws on both so the operator could now safely use a screwdriver to make adjustments with. The economizer jet did not make any significant improvement. The TSX 33 Unit had the cast recessed on the unit ID Tag boss. The TSX-241 unit changed that to a riveted brass date Code ID Tag with the Model Number and the date the M/S unit was manufactured. In the photo, the 241 shown has the 'TSX-241-B' model number and the date code of '4 51', defined as April, 1951. The TISCO Carb Rebuild Kit, p/n C546V, is the best kit to purchase today as it contains most all parts. It will rebuild all 9N, 2N, and 8N units and older jet screws replace the previous versions.
Marvel-Schebler model & (Ford Part Number):
TSX-33 (9N-9510) - thru s/n 260596
TSX-38 (2N-9510) used in 43 on Industrial Tractors and the Steel-Wheel wartime model only. Uses the double throw choke lever as a 2nd choke rod ran to the front grille. Mid 1943 declared obsolete and Ford went back to the TSX-33 as standard 2N production ramped up. The TSX-33 carb was used up thru mid-8N production.
TSX-241 (8N-9510) - thru s/n 276115
TSX-241A - thru s/n 313112
TSX-241B - thru s/n 313112 up
TSX-241C - used on early 1952 production, cheaper construction, had no econo jet
but was superseded by the TSX- 241B unit that eventually also superseded all others.
Other Ford Carbs:
TSX-428, EAE9510C, B2NN9510A, NAA
TSX-580, EAE9510D, B4NN9510A, 600/700
TSX-593, EAF9510D, 800/900
TSX-706, EAF9510G, B6NN9510A, 800/900 used on early models
TSX-692, 310746, 601/701
TSX-771, 312778, 801/901
TSX-662, 310015, 801/901 used on mid-production models
TSX-769, 312955, 801/901 also used on mid-production models
TSX-765, 312954, B8NN9510A, 601/701
TSX-813, C0NN9510C, C0NN9510G, 801/901/4000
TSX-33 - 9N, 2N, EARLY 8N
TSX-38 - 9N/2N INDUSTRIAL & 2N WARTIME MODELS ONLY. Mid 1943, declared obsolete, reintroduced the TSX-33 unit and used up thru early/mid 8N production.
TSX-241A, 241B,TSX-241C - 8N
FORD TRACTOR 9N-9510 CARB; MARVEL-SCHEBLER TSX 33:
FORD TRACTOR 9N-9510 CARB; MARVEL-SCHEBLER TSX 241:
TISCO CARB REBUILD KIT CV546V:
Tim Daley(MI)
