Has enough oil in the system?Got my "D" running pretty good now. My problem now is hydraulics not working. Is there a place that sells or services these? Thank you.
I was unaware of that. I will check that out tomorrow. Would be great if thats all it is. If its not I'll check the chain. You guys are giving me courage to get into it -thanks guysIs the main clutch engaged? Is the PTO engaged? Hydraulics work only with the PTO running and the main clutch is engaged.
Idk, infrared thermometer doesn't show much difference between top and bottom of radiator. When I remove radiator cover I don't see much movement in the antifreeze. You can drive it 15 minutes or so before before it starts steaming. I'm not sure if this has a thermostat. I gotta get a new temp. gauge so I can get a better handle on thisOk, the water is getting hot, you are on the right track, pay attention those radiators are heavy. Good luck!
Steam comes out around the cap. Didn't think about non pressurized part. Don't know what would be an acceptable amount. I flushed the radiator back when I went through the tractor. I need to get that gauge.What do you mean by steaming? That is not a pressurized system so they will steam a bit when warm. Is it cooking over? But there should be a lot of water moving in the radiator when it's running, so if that's not happening it could be the water pump. Those are tough to replace, so read up on the process to avoid problems.
Fan belt is good and tight. The generator isn't charging so I think an alternator is in the future. I will get a new belt(2) when that happens.More good advice has been given, A good temp gauge is needed, How is your fan belt? Is it in good shape and properly tensioned? There is no thermostat in this tractor.
