New to Forum and have question Re my Dad s old 1944 2N with 12V conversion. Sorry for long post. Tractor was running hot after just few minutes of work. Replaced radiator (which had crack in filler neck), water pump (super old and decided to replace while had hood off) and thermostat. Decided to change fan belt which was in bad shape and found that whoever had done the 12v conversion previously used old generator-size belt and an alternator with large pulley and an old top bracket they d tried to beat and bend to make fit. Belt was super loose and no room left on bracket to pull it tight. So decided to change alternator to one with smaller pulley and top alternator bracket to one that mounts under the two right-front cylinder head studs. NOW THE PROBLEM: When I was unscrewing bolt on right front corner cylinder head stud to put on new bracket, the nut was frozen to stud and when I thought I was unscrewing the nut, I actually unscrewed the entire stud from the bottom. I put the alternator bracket on and screwed stud back in with frozen nut still on it. Seemed to be tightening down okay with torque wrench at first but then just when it felt like it was torquing down to a stopping point (but before I felt torque wrench click) it went loose again. I was not bearing down much at all on it. I m afraid to keep cranking on it for fear I m stripping the threads down in block at other end of stud? Or is it just not getting to tightening point because of additional thickness of alternator bracket under the nut? What do I need to do to solve this problem before I make an expensive mess?
Tractor runs great when I start it. Only ran it a couple minutes and haven t put it to any real work yet. Notice some thin liquid now gathering around top of that front-right corner head stud and trickling down under alternator. Is that coolant? How serious a problem do I have here? Will a new longer head stud and new nut fix this? Thanks in advance for all input.
