Anonymous-0
I've got a 1948 D2 and have been working on rebuilding the pony clutch and pinion. I bought a new oring seal 2A-3676 from CAT and thought it looked too thick to squeeze down properly like an oring should. As I was installing the housing there was no way the assembly would push into the flywheel housing and compress the oring by hand, very tight fit. So I started a couple bolts and was slowly trying to pull the housing in and compress the oring. Well, needless to say it got pretty tight and I heard a pop, stopped and it broke one if the ears on the pony clutch housing. Is this supposed to be this tight? I did have lubrication on the oring. Now I need to either fix the housing, which might be very hard since its cast iron or purchase a used housing. How hard will it be to come by one of these? Also, should it be this tight? Is there another oring that is better and not as tight. Just seems like way too much compression to me. Thanks, Nate.
