Cariboo4x4
I took this injection pump off a 310-B JD backhoe Here is the ID tag info:
Roosa Master
JD8331MD2406 2500
Model 1490843
AR-49904
I timed pump and engaged position as manual states to put in engaged position for removal.
I removed this screw and there was a bunch of small to curls of this rubber type material in this hole. In the meantime Ill try to find out what this material was from.
This fastener was also dripping diesel considerably and thats why I removed pump. I couldnt remove fastener on engine because fastener would hit block of engine.
Engine ran awesome aside from dripping diesel.
Roosa Master
JD8331MD2406 2500
Model 1490843
AR-49904
