Mr. T. Minnesota
Forum,
I have an old Pettibone log skidder with a Ford 172 industrial diesel engine in it. Started it this week and noticed the oil pressure not as it should be? Figured out there was a lot of fuel in the oil pan. Question is how did the fuel get into the oil pan? There are a couple of possible reasons.
1. Could leaving the fuel shut off open let fuel through the pump?
2. Could the injector pump have a bad seal between the injector pump and the oil pan? The injector pump is the distributor type.
3. Could the in and out lines to and from the injector pump not be set up as they should be? By this I mean the (in line) to the pump is ok but the outlet side(return line) of the injector has a plug in it. Will this make a difference?
4. One last hitch- it is a gravity type set up but has an electric fuel pump in the system. The fuel pump was in the unit when I bought it so I kept it in the system.
Any and all help is appreciated.
Mr. T. Minnesota
Mr. T. Minnesota
