FarmerBlair
I've been spending a lot of time trying to diagnose multiple issues with a 1963 Ford 4000 (gas) tractor that I got recently at an auction. Without going into all the details, I've replaced the points and condenser, adjusted valves, rebuilt the carb, adjusted timing using timing light, and checked the coil by swapping with another running 801 tractor. I finally got it to start tonight and it ran for about 3 minutes before quitting. It ran long enough that I could get a quick look at the timing, which was off but at least I could see numbers on the flywheel. The tractor ran smoothly and did not hesitate when using throttle... which was a first. But now I can't get it started.
Also, I've had to re-gap the points repeatedly as they don't seem to stay where they're set, with the gap tending to widen. Bizarre.
I used a spark plug tester and get a spark, but seems weak. Testing the plug spark directly by grounding on the tractor doesn't produce a strong spark. I noticed that if I run the starter (with key on) with the distributor cap and dust cap off, I can see a pretty distinct spark every time the points gap opens. Also, I noticed that the flash of the spark plug tester is not a single flicker, but multiple continuous flickers as the engine is cranked with the starter, with a bit of a brighter flash which I assume is the actual firing. This happens a lot on plug #1, with varying amounts on the other plugs. I think it was plug #3 that the test produced a relatively clean single flicker without all the background flickering. Even though it's new, could this indicate the condenser is bad?
Thanks!
Thanks!
