(quoted from post at 06:57:43 04/25/23)
It was the original mode of the forum software from years ago, and many folks on here, if you haven't noticed yet, are older and set in their ways, and are unwilling to change on certain things. It also shows discussions in a "tree" view which allows you to see which poss are responses to which previous posts. I use modern view, so I always include at least a partial quote of the post that I am replying to so that you know I'm replying to you.
It's definitely an outdated forum. I'm surprised it doesn't get hacked running code this old. It looks to be running a codebase that is 15+ years out of date.
Anyway.
Did some work today with the tractor. I've been clearing deadfall trees and piling them up and now I'm finally FINALLY done with that step and now it's time to process the trees. My basic plan of attack:
- Pile up trees (done)
- Chainsaw trees into small pieces and sort into firewood, chipp-able wood, and trash that gets dumped into the forest
- Feed chippable wood into PTO chipper
- Dump whatever is left into the woods
I'm really not happy with my PTO chipper. You can't just feed it whatever, you can basically only feed it sticks, single-file. It is marketed as capable of up to 5" logs. If this was true, it would be perfect for me, because anything larger than 4" is firewood anyway.
Unfortunately I do not believe it is fairly marketed. I broke 2 shear bolts today on logs that were 3". I know this because after pulling the second log out of the chipper I went and measured it with caliper gauges. At least the shear bolts are easy to replace but what a pain. I wish I could get my money back.
After finishing up for the day I set out to fix a hydraulic oil leak on the tractor. Ever since I added the hydraulic top link I've been getting puddles underneath. Nothing major, but still needs to be fixed. I tracked the leaks to the 3/8" -> 1/2" adapter bushings connecting the pioneer quick connect fittings to the 3/8" hose. I thought I had tightened these pretty well initially, but both were leaking. Without taking anything apart, I threw some wrenches on them and was surprised to see that I got about a quarter turn on both of them.
I suspect there is about a 50% chance that fixed the problem. If not, I have hydraulic sealant I bought from TSC, so I'll try that next.
Other than that, the tractor is running great. Very happy with it overall. I only have about 5 hours on it but it's treating me well and I would buy it again.
