Hello everyone, really appreciate some help and knowledge here.
My grandpa who has mild dementia in his 80s took of on the 3600 and I found it out in the field, I thought he possibly forgot to turn the fuel on but looks like I have bigger issue.
Like before I thought I would just need to bleed filter and injectors and it would fire off, but looks like I may have bigger issue.
I have new filter installed, I've got fuel filter bleed and getting fuel at the injectors when opening nuts there.
What should my next step be to troubleshot can anyone help me understand what makes the compression and firing on these diesels?
My thoughts,
1. Never had to use ether on this tractor, is it safe to try and give it a small hit and see if I get it to light? This would probably be my next thought, but wanted to check here first.
2. I don't know how long he possibly tried to crank the tractor could I have too much fuel in the piston bowl; should I pull injectors and turn engine over to try remove possible excess fuel in piston bowl?
3. Further ways I can troubleshoot narrow down to injection pump or injector possibly?
Pump and injectors are original
Thank you
My thoughts,
Thank you
