FarmerBlair
So I've posted recently about my 1963 Ford 4000 select-o-speed tractor regarding running rough. I am at a loss as to what may be going on. Now I can't even start it.
When it was running, it would run rough, especially after warming up. I adjusted valves which helped with compression, which is now about 125-90-90-125. I replaced the points and adjusted gaps on that and plugs. This also helped. It ran well enough that I used it for about an hour in the field with a field cultivator. It ran okay, though it still would be a little rough and sound like it was misfiring a bit.
Later, I checked timing with timing light and found it to be a little off, so tried adjusting distributor so it was 4-degrees at idle, and about 24-degrees at 2200rpm. I couldn't set both, as it was about 5 degrees off when setting one versus the other, so I tried to compromise in the middle. After that it would run really bad and die in a minute or two, and hard to restart. I tried moving distributor back to the original setting, with no improvement. Now it won't start at all. Gas is coming out the carburetor air intake (found after removing air filter tube). Plugs were wet so I dried them and reinstalled. Checked points again and they are okay. Tried resetting time by rotating piston #1 to compression position and slightly adjusted distributor points gap open at #1. Still no start. Used spark plug tester and all plugs getting spark. Swapped out 6 volt coil from my running 881 tractor. That did not help, and the 4000 coil worked fine on the 881.
When trying to start, there is a frequent "jolt" or kick against the starter that abruptly stops the starter briefly. It would about shake the tractor when it happens. If I pulled the wire from the coil so there is no spark, the starter would turn with no sign of this kicking. It's almost as if the engine is kicking in the opposite direction against the starter.
I ordered a complete carb rebuild kit since fuel was flooding out, and I had some carb issues anyway. But does this sound like just a carb problem? It was at least start fairly easily before I started messing with the timing.
