Pine Hills
Hi, I've recently taken over my fathers 1981 (I believe) Ford 4610 2WD with 6,400 hours. Due to deteriorating health he hasn't completed any servicing for quite some time (many years), but at the same time the tractor hasn't had a great deal of use.
One service aspect I want to complete is the front and rear fuel filter replacement. I have managed to track down an old operators manual which says the rear element should be replaced and that the front element should only be changed by a Ford dealer. Is there a good reason for this? I'm not too mechanically minded, but can I apply the same process for replacing the rear element as with the front element? The manual shows the steps to take for this rear element replacement.
Secondly, the current rear element is a Donaldson P557111. Is this filter sufficient to be used as both a front and rear element for this tractor? Does it have the correct micron rating?
Are there any other things I should be aware of when it comes to carrying out this maintenance?
Many thanks in advance.
This post was edited by Pine Hills on 07/23/2022 at 10:13 pm.
