Hi,
I am currently in the throws of a full rebuild on a ford 861 diesel. I think but do not know that the PO ran it out of oil and it spun rod bearings 2&3 and the middle main bearing.
I got the crank ground to 0.020" under and it is still not cleaned up. I do not think I will run it like it is (pics attached).
This is the old style engine with no balancer.
1. Should I get the crank welded and ground on the rod journal that is shown? From what I understand these engines are prone to crank failure and many do not recommend grinding at all.
2. What are options for replacement cranks? There are a few good used ones out there but they may need grinding. Then I seem to be right back where I started. Is the on one the store here a good crank?
3. Can I put a crank with the balancer teeth in the pre-balancer engine? Do I need to add a balancer to this engine to help the crank life?
I would appreciate any advice! I do not want to put this together only to have to take it apart again!
video if anyone cares - https://youtu.be/PJ6PaEFt-dU
