Hobo,NC
- Location
- Sanford, NC
First the tractor numbers I come up with a 1970 2000.
B1023C
C279734
My neighbor sold me her tractor her son started on it and never finished. (Son Passed away she's selling the place) I got it together enoufh to trailer it to the shop.
I know it ran but needed some TLC he put a clutch in it I helped him mate it back together that's where he stopped. I got the power steering lines hooked up and checked the fluids I may fire it up tomorrow to make sure all's well before put the fuel tank and dash on it. I got busy in the shop so have not had much time to mess with it. I cleaned the fuel tank and prepped it for Por-15 last Sunday.
Fuel sender was a trip to repair most every connection was bad I solider them.
I was still getting wack-o-ohm readings WTF then I seen this wire from the pivot on the sender arm to the sender body so I tugged on it and it fell apart.
If I knew I could get the correct sender I would just buy one. This is what I came up with. I have a piece of the wire in a bottle of gas to make sure its gas safe.
For your info this sender and one off a 1980 545A read
Empty 210 ohms
Full 19 ohms
If all goes well the PTO seal is leaking it had a 8 speed and live PTO. I think I have read engage the PTO when removing it ?
The brakes are not good I had to stand on them hard to stop it when rolling it off the trailer. I know the right axle seal is leaking. I also know the right lower lift link is lose in the housing. Question do I remove the right axle housing are the left and slip out the differential to get to the lift pin.
I did get the por-15 in the tank today. I would have brought a new tank the last one I brought for a 545 did not fit well : ( Everything about it was a fight so I had rater fight the old tank : ) Side note one day I would like to try Red Coat fuel tank liner.
This post was edited by Hobo,NC on 07/01/2022 at 06:12 pm.
B1023C
C279734
Empty 210 ohms
Full 19 ohms
