goes back threw your sediment bowl,it needs rebuilt or replaced,I have one for sale.If the sediment bowl has an oil line going to it too.
You need to turn the gas of every time before u shut it off. First turn the gas off then let it run till it shuts off.
Well I think I was told the oil line going to the sement bowl was to cut the gas off if your engine was low of oil so you wouldn't ruin it,and there is a gasket there that helps do this , when it goes bad it allows the gas to run back to the crank case, I suggest asking Mr. Thinker for a 3rd opion.
this unit is a fuel shut off operates off oil psi it has two diaframes in it also has rubber washer on stem that is opened by oil psi diaframes leakback thru oil line into crankcase there is no other shutoff valve on this model tractor these parts easy to get
My 530 has no mechanical shutoff, only oil pressure actuated. My 720 has both mechanical and
oil pressure actuated gas shutoffs, so I can shut
it off if I don't forget.
It appears that I need Diaphrams 4983R. Cannot find new ones... do you have a Source for me?
Thanks!
