Nyquil Junkie
We need another tractor here for moving hay rolls around, all on flat ground more or less. We have the 64 4000 backhoe 4cyl diesel, and it works just fine doing the job. A second tractor like this one is what I am looking for now, and here comes my question....
We start this old diesel up about every other day, run it for 10 min and shut it down. Thats all the time it takes to run a bale out. The engine never gets past 120 ish, so never gets up to op temp. Sometimes when we are moving a lot of hay around it does, sure but that is a rare work day.
So I am wondering if doing that to this old diesel engine is "bad" for it in some way. Lately the dry engine has begun to weep oil, it seems like either the valve cover side cover or maybe the bottom head gasket, I'm not real sure. Probably just typical of an old engine but I wonder if the way we use it is contributing to the slight but noticeable leaks. A few drips a day from where it ends up on the bottom of the pan just yet.
Anyhow... would a gas engine be more suited to this short run constant use? This 4000 is the only diesel we have ever had so... what I know about diesels can fit in a coffee cup.
So should I be looking for a gas engine over a diesel for this work? I'd like to just put the bucket back on this 4000 and use it for what it is... a backhoe.
