Anonymous-0
does anyone have pictures of a homemade gravel drag they have made to use behind there "n" with a pole where you can lift off the ground? I have a weilder and can fab, just need some ideas. thanks
(quoted from post at 07:36:53 08/17/12)[/URL]
Here is a driveway grader I just completed. I have the plans available.
One thing I would advise, make it as heavy as your tractor can handle. I have read that 110 lbs per foot of width is recommended, and after using it, I would agree. This one is 6' wide. The wheels on my 8N were just starting to lose traction when I was dragging this up a slight hill in the gravel. I lifted the 3PH just a bit, which put more weight on the tractor, and all was good. This thing does an excellent job at smoothing out my 1/2 mile gravel driveway.[/img]
