Mnethercutt
I have several problems with my 1010RS Dual hydraulics. First off, is the oil supposed to be poured into the oil cap at the front of the hydraulic quadrant? If so, how high does it need to be filled? I filled it to the top and when I started the tractor it spewed out hydraulic fluid w/ the cap on for a good 30 seconds before it calmed down and the hydraulics kept working. Also, I replaced the oil seals on the rockshaft arm, but the left side is still leaking. What can I do to fix that?
Also, how can I tell if my voltage regulator is bad? I rebuilt and tested my generator, but the tractor doesn't seem to be charging the battery (12.3ish volts at the battery when running at 1400 RPM).
Thanks in advance.
Thanks in advance.
