Back again with continuing problems with a new ignitor electronic ignition installation. I bench tested the ignitor furnished with the original purchase of the system containing an ignitor, 4,000volt coil, a new distributor cap, a rotor and plate to hook the new coil wire to the distributor. I tested for problems including reinstalling the points back in the distributor with no problems. The 9N tractor ran good with the points back in it. I then run a test provided for by Pertronix to test the ignitor and the ignitor did not perform according to their test results indicating a bad ignitor. I called their toll free number and after doing some tests for them, they sent me another ignitor.
I installed the new ignitor and the engine still does not start and run. I get no sparks to the spark plugs. I'm getting power to the coil. With my DC tester on the positive and neg poles of the coil, I'm getting juice there. However, when I turn on the switch and check the coil to distributor wire with negative to battery I get continuous voltage with no fluctuation when I engage the starter. In other words, I'm getting continuous juice to the distributer but it is not being distributed to the plugs for some reason. This indicates that the spinning of the rotor is not getting juice to the plugs. I'm confused by this since the distributor cap is new and the rotor is new. I checked the rotor for proper installation and it is good. Also, the voltage going to the distributor appears to be no different than that going into the coil from the switch. I know that the distributor parts other than the ignitor and coil is working good since the tractor run good with the points installed. What am I missing other than my questions about the coil, that I have indicated above? And, if it is the coil; what test do I need to check it out further? If I had not already purchased this electronic ignition with no return, I would go back to the points since they were performing pretty good.
