IH 1086 Temp gauge
cstrucks
I have a IH 1086 that the temp gauge stopped working on. I have tried but cant seem to make it work. I can remove the wire off the sending unit and ground it and the gauge pegs out like it should. I replaced the sending unit and still dosent work. The needle stays to the left and never moves up to the green like it should. Anyone have any suggestions im stumped. I have also changed the gauge but still nothing. Thanks
If the gauge pegs all the way hot when you ground the wire then your gauge is working. You may have gotten a bad sender unit. Did you replace the sender unit with oem part?
