I presume several models of IH tractors used the same fuel/gas shut off.
our 444 gaser is leaking around the gas shut off valve stem. it didn't used to leak but i have been shutting it off and undoing the electric fuel pump wire to sort of disable it so if someone was going to try to steal it maybe they wouldn't get very far and give up.
anyhow i suspect that since i've been turning it more that it has loosed something up. dirt inside valve? the nut holding the stem in is loose?? worn out?
any suggestions? has/had about 1/2 a tank of gas and is not leaking alot but always has a couple large drops of gas hanging on the knob and near the sediment bowl.
Thanks.
Thanks.
