In the process of setting my lifters.
Ol 54'
Have never set a set of lifters on an Oliver 55. What am I up against here farmer's, they just seem a little looose and while I was going to replace the valve cover gasket thought I would take a look at adjusting the lifters. I have set lifters on small block chevys, also what is the exhaust and intake set at? Thank you..
here is the specs from IT manual. Use the same principle that you used on your SBC to ensure you are on the base lobe of cam.
