I wanted to see if anyone had any ideas on what to check. The short story is the hydraulic lines were swapped with new lines and now the Front end loader does not work. Neither lift nor bucket.
The long story:
I have a JD 2440 with JD 146 Loader. It's only used occasionally and alternator went out years ago and finally starter went out so I decided to get some maintenance done. I'm decent with electrical but mechanical I'm not that great. The starter was really a bear to get the bolts out so I hired a guy to come replace alternator, starter and replace hydraulic hoses since it has sat outside for about 15 years. All the parts were pulled off on a Sunday afternoon and I ordered replacement parts that night. Took the hoses to a local hose place on Monday. It was the following weekend before we got back to replacement, during that week we got quite a bit of rain and I did not think about the hydraulic ports getting water in them. Starter went back on but I was missing the pulley from the alternator that had been hauled away for scrap so this meant I couldn't start the tractor after the hoses went back on. After locating a pulley, I put the alternator on and started the tractor, and now the loader does not work. It will be awhile until I can get my mechanic back to look at it so I'm trying to determine the problem.
When I run the tractor the 3pt lift seems to work fine. The loader lift will go up just a bit when I rock the hand control lever but it seems to be opposite of the way it should be. Push forward, lift goes up. When I pull back the lift does nothing. All the hoses on the bucket and lift appear to be correct, they were marked with color-coded zip ties before removal and they all match. I'm wondering if the hoses from the loader hand valve back to the tractor hydraulic pump might be reversed. I have posted some video and pictures at the link below if anyone would be willing to take a look and give me an opinion.
The long story:
