I have an '83 JD 850 1500 hours, 2WD non-power steering (no external hydraulic filter) tractor. The tractor starts and runs great but I'm having problems positioning the 3pt lift.
The lift does go up and down but there is only one spot in the lever travel that lifts (at the top of the range), one spot that stops the lift arms (just off the top of the range) and all other positions of the lever release pressure and drop the arms.
I have changed the fluid and cleaned the internal screen (it was dirty). I have also cleaned and lubed all the control levers and bars. Everything on the control side moves freely without any binding and nothing looks bent.
The push valve on the top of the rock arm moves freely. Pushed in the lift goes up, placed in the center the lift stops moving and out it drops the lift.
Is the push valve only suppose to have 3 positions or is it suppose to place the lift according to how far it is pressed? How is this suppose to work? I do have the shop manual but this is not covered!
If there is anyone on the Raleigh NC area with a working 3pt on a JD 850 or a Yanmar 2610? who would be willing to let me look at it in operation that would be great.
