JD3010_1961
I think I have determined that the transmission oil pump in jd 3010 needs to be replaced. Do any one know if this can be done thru the top by pulling the rock shaft housing or does this require a split at the transmission. Its a 1961 jd 3010 diesel row crop with a synchro range tranmission.
Diagnosis: drained transmission fluid. Checked sump screen, it was clean. Changed hydraulic filter. Filled with new transmission fluid. Separated the delivery line just under the clutch pedal. Cranked it over and not a drop came out of the tube. Any ideas, Thanks.
