Morgan Flowers
I have a John Deere 310A backhoe loader that will not move and has no functioning hydraulics. It started out acting like the clutch was "slipping" and then a few days later it quit moving altogether but the loader and backhoe still functioned. Now all hydraulics have quit as well. Here is everything that I have tried so far.
- Removed and replaced both hydraulic filters
- Removed and cleaned sump screen
- Inspected relief valve in filter housing
- Checked transmission oil pressure at the bottom of the reverser test port. At fast idle I am getting 90 psi when the reverser is in neutral. If it is in Forward or Reverse it drops to 0. Even when the trans pump pressure is 90 psi no hydraulics will function. Does anyone have any ideas or know what I can do? The pressure comes up to 90 psi slowly even at fast idle. Thank you in advance for all your help.
