Iv'e posted in the recent past about my 1953 Jubilee hydraulic problems. Here's a recap from what Iv'e done and where I'm at:
The 3 point always bobbed a little and dropped down after shutting off in the up position - it's did it for years, Iv'e owned it for 29 years. Never an issue really for me. Recently it was slow to raise, I saw with an inspection mirror the safety valve was leaking. Took the top cover off and noticed the valve had backed out/unscrewed from the housing. I screwed it back in with no leak (and replaced the hydraulic piston O ring and leather washer). The back pressure valve gasket fell out making it leak in another spot of course. Replaced the gasket and tried again. This time I had foamy hydraulic oil - had an air leak on the suction line. I fixed it with no leak again ( started the tractor with the top cover off, I put a clear plastic line in the pressure opening and it pumped clear fluid instantly back in the reservoir. Now when I start the tractor even with the control lever all the way down (lowered) the 3 point arms will raise up all the way, right away. The entire top cover looks to be in very good shape, no rust or wear spots, everything seems tight and operable. The control lever works the control valve as it should - back and fort with no binding. The safety vale does not leak, I replaced the 7/16 steel check ball too ( the check ball seat looks very good). So, as it sits right now, the tractor starts up and the 3 point arms raise up all the way, right away even though the control lever is all the way down - it operated as it should when on the bench. I do have hydraulic fluid pouring out the opposite end of the safety and control valve side which is the baffle plate according to my IT manual. As soon as I can get the baffle plate from leaking, I might get it!, but, I don't know what the next step is. Does anyone know what the issue is? THANK YOU!
