Douglas Lloyd
Well, just got the 12V conversion kit from Just 8N"s and it is a one wire kit.
I"m doing this conversion to a stock "52 8N sidemount distributor with conventional points. It runs OK, but nothing fancy and the 6V battery is about gone.
The wiring diagram included with the kit is the same one that has been posted repeatedly for 8N sidemount distributors.
The alternator looks like others pictured in past posts - a 10si self exciting type, and it comes with the wider pulley already installed. Quality Tractor Supply Part #3000-0502. It has the large red BAT terminal and a rubber cap plug where the plastic wiring plug for the 1(R) & 2(F) connections would go. Looks like this would come out but haven"t tried to yank on it.
Searching the archives, back in July of 2011 there was some discussion about how to mod the 1 wire kit to a 3 wire setup. I could not find a diagram for this. There was also some suggestion that not all 1 wire alternators need to be revved up to start charging. Thoughts?
I already bought the Just 8N"s 3 wire diode wire to use with the kit, but still have the stock "fat sister" ignition switch (thank you Dell!) with no ACC position. Also my ammeter is the post style.
I want to do this one right. I don"t run this N at high revs unless necessary. I"d like to have this thing keep the battery charged when just puttering around the pastures. I can follow directions but I like diagrams. Do I install this kit as is, or go the three wire route?
Once again, this forum sure has helped me come to terms with Ford tractors and I appreciate the help.
Doug Lloyd
Kingston, TN
Doug Lloyd
Kingston, TN
