Cavtrooper
- Location
- Oklahoma
I have the manual. Sometimes with my TBI brain I have a hard time picturing what the words are trying to tell me. Thanks.I'm sue there are other methods besides the below procedure..
Don't overlook the bolts that go into timing gear cover.So I started pulling stuff off to change the oil pan gasket and when I went to drain the oil there was MAYBE a quart and a half in the oil pan. Also I wonder if when the PO “changed” the oil he really messed the process up because he used what looks like cheap RTV for a gasket on a plate underneath the tractor and forward of the PTO.
Other than that I’m just having a hard time getting the oil pan to drop. I don’t want to force anything and end up breaking something so I’m being extra cautious.
I’ll double check when I go out there today.Don't overlook the bolts that go into timing gear cover.
There were no rubber pads under the radiator. I’ll have to fashion some. I’ll keep playing with the radiator and see if I can figure something out.Don't delete the shroud, it makes a big difference. Make sure your radiator has thick rubber pads on the bottom between the frame and radiator bottom where the bolts are, it positions the shroud better. Also, you can tilt the radiator away from the body and this helps as well.
Rear Main Seal.........Engine......?Go the shroud fixed and got the thing back together only to find my rear main seal is leaking. Gonna have to find a place that can split the tractor and do that repair. I don’t have the capability.
Yep. After drove it around the block a few times I noticed oil coming out from where you’d split it just about underneath the seatRear Main Seal.........Engine......?
Appears to have a Sherman transmission (Hi - Low range) option.What is the lever on the left side? Not the pto. The other one? A different auxiliary hi lo?
Any chance of a photo?Hi yall
I picked up a brush hog yesterday and the driveshaft is about 12 inches too short. Will I need to measure in order to get one to fit it or are there standard sizes?
