will-max dairy
Give yourself and the machinist a little grace. One thing that isn't often mentioned with these old N tractors... is that their PTO shaft is smaller than modern shafts. They were originally 1-1/8", six spline, shafts. Starting somewhere in the 50s or 60s, the industry started to standardize on a 1-3/8", six spline shaft.Frustration ensued anyway. The new one won’t fit over the overrun clutch that’s on there and the machinist was acting like I was an idiot when I told him it didn’t fit.![]()
If your overrunning clutch is like mine...it has a 1-1/8" female, to match the N tractor, and a 1-3/8" male to fit modern, standard PTO shafts.
Your machinist may have thought they were doing you a favor by using a 1-1/8" female to fit an N tractor, not knowing that your overrunning clutch adapts to the new standard.
Of course, this is all conjecture on my part. But... if you have a set of calipers, measure your overrunning clutch male end and the female of your new PTO assembly... you may find that it's just a miscommunication.
Or... if you, or a friend, have a newer farm tractor around... test fit your old mower PTO shaft on the newer tractor... and then try to test fit your new one. That may be easier than trying to figure out the difference between 1-1/8" and 1-3/8" on a six spline female coupler using calipers.
I find my own answer a little ironic, as I was commenting on another thread about how valuable I consider old N tractors to be... and they are, if they are kept in good condition... but... they have quirks that can easily cause these kinds of misunderstandings...
